What kind of links? There are different ways that you can do this, but it all depends on your WAN linksHi guys, I need to set up load balancing for an implementation. We have 2 WAN links, one 10 MBs, the other 2.
Can anyone link to a site where I can find information on how to implement a Dual WAN failover configuration?
Not if they're TDM links, which would allow for multilinks and the sum of both links. 12Mpbs sounds better than 10 to meSounds like you just want failover considering the difference in bandwidth.
Tu shea good sir! for some reason when I read the thread all I saw in my mind was 18xx... then when you posted I was like "wtf, no... hes using an 1841, 2 WIC/VIC slots".Considering the 1811 is a fixed router with 2 FastE interfaces and a dial backup, it's probably not TDM![]()
Might as well go with OER, moar bandwidth = better
Look at the link that I posted dude, Wes also made a walkthrough that you commented in yourself a few weeks back. I also told you to implement this(sub automatic loadbalancing) when you wrote your NAT article months agoYou misunderstood. I'm asking what he would use to load balance across unequal links. I wasn't aware that you could do that with OER, if so, post a link or some config cause I can't think of a way to do it.
The loadbalance is per-session, every other session is NAT'd out the next interface. You can disable CEF for a true round robin loadbalance but may encounter countless packet routing issues.
Clearly you dont understand it, and no... I told you about how to do this MONTHS before Wes thread and your conversation with Calvin. Again, bandwidth doesn't come into play here. EACH session is divided equally across each link regardless of bandwidth(this is also what Wes showed in his thread). If you want per-packet loadbalancing then you must disable CEF(which 99% of people dont realize, which is clarified in Wes's thread)Right, I know how to load balance. This is unequal bandwidth though, wouldn't it be load balancing evenly across the links? Which would be a bad thing.
Also, I commented on Wes's post because I had just explained to Calvin how to accomplish it, which I think I told you about. So I don't see how you think I've forgotten how to configure this stuff in a week...
Ill summarize our AIM convo here for the OP so he is aware. I agree with you that it may be suboptimal in some cases, and more often then not you would have a 50/50 chance of sending *more* traffic over a slower link. This is the nature of why NAT loadbalancing is kind of shitty but thats what the way it is.The sessions are divided EQUALLY (as you said) across each link, that is my point. That is suboptimal if one link is 5x faster than the other. You disagree?
they sound like a married couple....![]()
LOL, you have a point there.they sound like a married couple....![]()
You're absolutely correct about network design(asking questions), but he is not asking for design support. I asked the only question necessary in this situation, anything else would have been redundant and a non-issue question.anyway, depending on the needs of the persons using the links determines the decision to load balance or failover the 2Mb link....this is basic network design people...ASK QUESTONS, what does the business want/need from the infrastructure. our jobs as the network admins/designers is to interpret the business model and determine what can be done with/to the network to get as closely accomplished what needs done.
