Hi,
I'm starting to get into streaming and I'm not quite an audio wizard, but here's what I have so far:
Free virtual audio cable driver:
VB-Audio Virtual Apps
Reaper (real time ability to modify my voice):
REAPER | Audio Production Without Limits
Free tool to record your screen:
Open Broadcaster Software - Index
I have reaper configured to use my microphone as input and the virtual cable as output.
I have OBS set to use the virtual cable as mic input.
At this point, things work correctly. My modified voice from reaper is getting output through OBS's audio channel and things are good.
But here's the problem / question:
How can I get reaper's live monitor to play back the effects through my speakers so that I can hear it before I record it in OSB? I want to just sit here for some time tweaking plugins to get a good sound for my voice, but I can't do this without first recording it in OSB and playing it back, which is killing me.
I feel like the root cause of the issue is I have no idea how to get a virtual audio cable's output to also play through my speakers.
In control panel I have my speakers set as the default playback device but I also tried changing this to the virtual audio cable with no luck.
