how to force directx 8 mode
You could use 3D Analyze to trick the game into thinking that you have a DX8 card.
easier way would be to add -dxlevel 80 to the launch options.
Edit: oops my stoned ass misread that
Create an autoexec.cfg file in \HL2\hl2\cfg\ and add this line:
mat_dxlevel "81"
Oldmx
I really dont think you can force Direct X 8 for every game out there, by some special file. Its either the game will only run in Direct X 9 or there is an option in the game options menu to change it to Direct X 8 shaders, or a console line that you have to go searching on the internet for.
