mista ting
- Apr 13, 2006
Pretty sure you all have this problem and every one told you to DISABLE power management which is wrong......finally figured out how to fix it.
1. go to your network adapters properties
2. go to the "power management tab"
3. Check "Allow the computer to turn off this device to save power" ------- ENABLE IT NOT DISABLE
4. Check "Allow this device to wake this computer" ------ ENABLE IT NOT DISABLE
5. click ok
it should look like this
5. click ok
![j0dxc9.png](http://i42.tinypic.com/j0dxc9.png)
