Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I know you're supposed to be able to drain lines using quick disconnects, but what should I use to press down on the middle? A screwdriver? Allen wrench?
Your supposed to use a extra Male or Female disconnect. So if your using a set of M/F inline, disconnect the two ends, and attach an extra opposite disconnect on one end to a length of tubing and drop the other into your draining container. Also remember to unscrew a stop fitting off of your reservoir to release pressure to get water to flow.
Damn, so I have to get a second quickdisconnect to do that? Not really worth it. I have a drain line in my system already. However, I have quick disconnects on either side of my gpu blocks, and I wnat to be able to drain the gpu blocks before I disassemble the bridge so as not to leak water everywhere when I unscrew the G1/4" thread.
