I did screw up little when I install WinRAR. It override ZIP file icon with its icon. I try to make the icon looks the same for zip file but can't find the "File Type" option under folder options anymore!
Any idea how to get it back? Try free program call iphile but it doesn't work. Try turning UAC off and it also can't override that.
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
