May 10, 2006 #1 M menlatin Gawd Joined Sep 4, 2004 Messages 612 As the subject says. How do i burn this kind of file. I assume its supposed to be like an .ISO file.
May 10, 2006 #2 F FanZ [H]ard|Gawd Joined May 7, 2002 Messages 1,969 i think alcohol 120 can do it.. its been awhile since i had it though but i think they're doing free trials.
May 10, 2006 #3 J jcmuse Limp Gawd Joined Feb 10, 2006 Messages 329 ImgBurn can do .MDS - http://www.imgburn.com/ a .mds usually links to some sort of image -- i'm guessing this is the .mdf. Just open the .mds in imgburn (a great program btw 100% free).
May 13, 2006 #4 B burningrave101 [H]F Junkie Joined Sep 9, 2003 Messages 11,825 .mds and .mdf are the file type used by Alcochol 120% and thats what i use to burn them or create them.
May 14, 2006 #5 D Deleted member 133315 Guest use nero and click on burn image, and it will burn the iso to the dvd/cd as it should be burnt. mdf/mds = Alchol120% image file. it can be burnt with any image burning program.
May 16, 2006 #6 J Javelin3o4 Gawd Joined Aug 19, 2004 Messages 717 I just done it by mounting the image with alcohol then using nero express cd/dvd copy
