Overkill-X
- Aug 19, 2003
The problem is as follows: I built a new machine, with a new main drive. So i figured, might aswell keep all the stuff on the "old" hdd and connect it to have a secondary hdd. Problem is that i cant access the data thats in my "user" map from the old drive. (Since it was password protected ----> windows login one)
So is there a way that i can type in the pass or something to acces the map?
