How Not To Fly A Wing Suit
I had a colleague whos good friend was killed in a similar setting, while his wife watched. Sadness.
Dude, that's NOT flying. It's falling. With a little bit of steering... like a guided bomb. It's nothing like flying like a Falcon.
If you insist on doing deathwish stunts and you want to "fly" then at least you could get into the jet pack suits. Then you are "flying".
I'm not going to knock someone for doing this and getting hurt while I sit behind a computer. The most I do is run and lift weights.
It looks like he lost altitude and didn't have time to maneuver.
Fucking mad props.
Fucking mad props.
It's not what he was doing, it's how he did it. Personally it looks like fun, but playing chicken with a fat tree or bridge is not.
I don't the adrenaline addiction. Too bad pretty most governments have made all the cool alternatives illegal
I read somewhere that this dude was stoked about his potential VA disability when he leaves the service.
Surprise, a Line of Duty determination will be on your record and will show your being a cripple is due to you being an idiot OFF DUTY. No disability for you.
Nope, this is flying. Gliding is just unpowered flight.
Source: I design things that fly, both powered and unpowered.
Reactions: N4CR
Seconded that with 105hrs PIC, + PPL and CPL theory passes.
As much as I hate to admit it.
These guys should learn to fly planes or similar first really. You'd then learn how and why flying close to mountains can be incredibly dangerous and give them the spatial awareness to avoid hitting the ground..
edit:Watching this first time, I could see his glide slope was towards that white scar in the rocks, I assumed he would turn and be close (but not so close!) and make it over top of trees - of course forgetting how much drag a turning, stubby wing suit must have. As soon as he got close to that, white scar, over the ridge, before 1:18 or so, I realized he was getting a little close for comfort, things not looking good, after the turn he lost so much speed and height, was then screwed.
That's experience and understanding a glide slope. Considering it's unpowered flight, he did not leave any margin of error prior to this either, for any air movement, regardless of when he's going towards the trees. Scary shit that you can do this without proper training.
there is no way his body hit that actual tree and snapped it. If he he did... he'd be in two pieces. it just snapped from him bending it from the top. and the tree "helped" him survive because of it. Well... i'm sure multiple trees did. If he went in a litttel lower, for example, he'd in in peices. So he survived most likely... due to hitting them in the "soft spot" (i.e. at the tops). :)
Reactions: c3k
Don't ruin a good story with facts!!
Was the tree broken before he hit it?
If YES, he did not break it.
If NO, he broke it.
Pretty simple.
Yeah considering they said "he always wanted to try this..." kind of suggests this was a first time for him, in which case WTF is your deal thinking you really know how to snake between tree lines.
