Well I tried to use the calculators that are found in the sticky but I one if them didn't work, the other one was really old and didn't have up to date parts. Ok so recently I got a new hard drive and since them occasionally my computer would restart, under what appeared to be heavy load, there wasn't any blue screen or anything, just a click and it would restart. Here are my specs:
ABIT NF-7S
Athlon XP 3200+
1gb DDR400 OCZ
6800GT
1 WD 120gb
1 Maxtor 120gb
1 Seagate 320gb
NEC DVD-RW
and about 4 fans
My power supply is an older 300W PSU that I got with the case, it's decent quality, but I don't think it can handle it anymore. I was looking at PC Power and Coolings power supplies, and I was hoping the Silencer 360 would be enough, since that already is quite expensive. I will probably be upgrading to an X2 3800+ in the near future so I would like to get a power supply that could hand that.
So the question is, will a PC Power and Cooling Silencer 360 provide enough power for my current system and an upgrade to a X2 3800+?
Thanks in advance.
ABIT NF-7S
Athlon XP 3200+
1gb DDR400 OCZ
6800GT
1 WD 120gb
1 Maxtor 120gb
1 Seagate 320gb
NEC DVD-RW
and about 4 fans
Thanks in advance.
