how much faster
AMDXP
just curious how much faster is a 6800gt compared to a 9800xt?
30%?
I know the 9800pro is 10% slower then the xt.
If you drop them both at the same time in a vacuum, they will both accelerate at the same rate and will have the same speed when measured at any point in their descent. If, however, you drop them in a gas, the xt will fall "faster" because it has a smaller surface area and hence less total drag force due to interaction with the gas.
edit: I will perform this benchmark if any of you would send me these cards.
Depends at what resolution, and in what game.
Why not look at some benchamrks and judge for yourself? They're everywhere - google is your friend.
Depends on how the cards fall though :) , if one is on its edge and the other on the flat side.
the radeon will still win either way, smaller heatsink and its not nearly as long
You are right. I would need to perform the test at least 20 times to be able to develop a statistically significant result. I can provide the stopwatch, the pen, and the ten story drop. Need volunteers on the cards.
hehe quite an expensive test :D
hah, too much
sheesh people, stay on topic. and i'm a physics major!
see my sig for hardware
using identical hardware except video cards, here are some benchies...
Both of these are scores with both cards moderately OCed
9800XT - 432 Core 390 Ram
6800GT OC - 400 Core 550 (1.1 Ghz) ram
