I'd check to see how many your case can hold first and then see where you want extra air flow. Also, the 120mm fans will push more air and be quieter than an 80mm fan. You can also always buy an 80mm to 92mm adapter and use a 92mm fan in it's place.How many case fans are ideal for good cooling? Right now I only have an 120mm stock case fan in there. They're pretty cheap, so I wouldn't mind buying another one if it will help.
My case(cm690) has alot of room for fans(9, 8 120mm and 1 80mm) I have 8 fans and it keeps it really cool But i would think that with good airflow 3 fans would be good.
A little bit but ive gotten use to it. You can always buy a fan controller.
If the system in your signature is accurate, then that 120mm is enough. I like to keep fans to a minimum as long as there is adequate cooling.
I actually just got a new computer. I'll update my signature. If the single 120mm fan was enough for that system, then it definitely won't be for my new one.
My current case only has room for an 80mm fan in the front. If I decide to get one, does it matter how/which way I install it?
