I(illa Bee said:A guy at work was telling me that sony way looseing $600 on each PS3 to put blueray in it..
Didnt sony invent or back; betamax, mini disk, superdisk(120mb floppy) and some other CD format... all failed...
I say wait for blueray to die then buy a HD burner.
swatbat said:Mini disk while considered a failure by many was kinda a cult hit amoung bands and used a lot to record audio. It was still a failure though
Tell that to all the people using Intel 965 boards.Gatticus said:Why not? I use both SATA and IDE and plan to continue to do so. There is a SATA model on that list but SATA brings no benefit over IDE for optical drives.
djnes said:Tell that to all the people using Intel 965 boards.
sn3ak3rp1mp said:Remember the DVD-R(W) / DVD+R(W) fiasco?
No?
What do you see now? Drives that will read / write BOTH formats, +/-
It's hard to even find single format DVD burners / readers now anyway.
So, /me is going to wait until we see a BluRay / HD DVD combo drive (highly likely) or one of the formats die (less likely)
Cheers!
J-Mag said:Most of the SATA optical drives I have seen are just IDE drives with IDE to SATA converters attached anyway... It wouldn't be that difficult to use one on a BR IDE device.
