Megalith
24-bit/48kHz
- Aug 20, 2006
I have no idea why, but my Internet connection is completely flaky unless I introduce a network switch between my router and computer. The motherboard on the computer with network issues uses the Intel 82574L and 82579V NICs. If I plug an ethernet cable directly from my router to the PC, the connection tends to randomly die for no inexplicable reason, requiring a complete restart of the machine before any connectivity can be restored. This happens regardless of which NIC I use (though it seems to be worse on the 82579V).
But once a network switch is entered into the equation, the connection is totally stable. The only issue I run into is that once in a while, the activity light on port one (the connection to my router) switches from green to amber, indicating there's a throughput issue (my 100 Mbps connection effectively drops to around 30 Mbps), but this goes away once I restart the switch by unplugging it.
Any ideas? I feel like there's something inherently wrong with the Intel NICs (Googling suggests there's some kind of packet bug in at least one of the models), but I'm not sure how a switch is keeping my connection from dying.
