When you move the lever down, does it just move the CPU pins into position and hold the CPU in place by just "grabbing" it?
The reason I ask is because I was removing the heatsink/fan from my new P4 CPU off of my new Asus PC4800E-Deluxe mobo and managed to yank the CPU out at the same time, with the socket locking lever still in the down position! I guess the thermal bonding between the heatsink and CPU was strong enough to pull the CPU out even with the CPU locked in place.
So I'm also wondering if I might have damaged the CPU or mobo in some way. After carefully slicing the CPU away from the heatsink, I put the CPU back in the socket but when I moved the lever back down, it kind of resisted with a grating sound. The PC then wouldn't boot or even go into POST. I tried this a couple of times before taking the CPU back out and reseating it. This time I noticed that the CPU didn't quite sit all the way in the socket so I gave it a slight push and it fell the rest of the way in. Then the socket arm locked in smoothly and after a getting past the mobo being confused about seeing a new CPU and what it thought was a failed overclocking attempt, the PC has been booting and running fine since last night. Also, I checked the CPU each time to make sure none of the pins were bent.
So, did I get lucky or do I have a time bomb on my hand? And is it more likely that the CPU or mobo got damaged when CPU came out? And am I the only joker that managed to do something like this?
Thanks,
Stephen
Thanks,
Stephen
