So I've got my new LCD and I'm loving it long time
I just wish to increase my understanding of LCD's and how they work, I just like to how things work.
I'm kind of under the impression that LCD's refresh each pixel at the same time rather than scanning from side to side and top to bottom like a traditional CRT does. I'm not quite sure why I assumed this I just did with the available information, maybe it's completely wrong but I'd like to be sure.
Does this mean that LCD's can't tear in the traditional sense? CRT's could tear because the image that is currently active on the cable (whatever is in the video cards buffer) would be rendered by the monitor despite where it was in the vertical scan, so if it was rendering frame 1 and got to the 30th line of pixels down the monitor and frame 1 was switched out to display frame 2 the monitor would carry on drawing row 31 from frame 2 and you'd end up with 1 image on the screen comprised of 2 or possibly more different frames.
If LCD's refresh 1 pixel, or row at a time, which order is it done?
Since LCD's also have a finite refresh time does that mean that they can have the frame change inbertween screen refreshes, if so do they use some kind of buffer to store the newest frame and then display it or what?
Thanks in advance for any info on the topic.
