- Apr 16, 2006
I down loaded Nvidia's nTune, a program that automaticly finds and optimises or overclock your system, and ran the automatic tune on fine tune which takes about 3 hours(+reboots) to overclock your system. Did a great job, everything ran smooth, never had BF2 load so fast on high settings, but this morning I restarted my system and everything was setback to normal (checked using Everest). I saved the profile, but I can't for the live of me find where too load those setting.
Another thing, can you use nTune and Coolbits or would that cause conflicts? I would assume you should run Coolbits first and then the nTune, since nTunes takes your whole system into account.
Thank you,
Dorian Lang
Thank you,
Dorian Lang
