The Lurker
- Jul 1, 2001
I have a server at home. Up until last week the only way for me to gain access to it from outside the network was through a VPN connection. I decided to setup seafile on it so I can get us off dropbox. Seafile works great but I am cautious about who I share links to files with. Its behind a router based firewall, windows firewall is enabled on it as well and only the necessary ports are open. I have done some light reading into setting up SSL but have not actually done it yet. I was thinking of setting up a dedicated machine with PFsense, but that may be overkill and added complexity.
It's running Windows 8.1 right now, but I can change that if necessary.
What can I do to make sure nothing heinous happens?
