Since I learned about ESD, I'm trying to piece together how I should properly handle PC equipment. One thing that I know nothing about, is the "grounding" of PC components, and I think this might be important to know when handling them (especially with danger from ESD).
I would like to know how components inside a PC are grounded and if the PC case itself is connected to the same ground? Does it have anything to do with the metal standoffs that support the motherboard?
