So in my new house they already have Cat5 jacks everywhere for the internet, and basically they wire the modem somewhere out of the way and then i go get a router or somesuch, with however many ports i want to be activated for use.
the thing is i want every Jack used to basically be just like the computer was hooked up straight to the modem. I dont want alot of the security or internal firewall and port forwarding issues that often come along with a router when it is tucked away somewhere anyway. I asked the guy about getting a switch instead, as that still has the same bandwith allocation ability a hub lacks but is essentialy dumber than a router, making it so every jack is effectivey still as unhindered as i would be hooking up straight to the modem.
but the guy said different he said: "As far as internet is concerned a switch can be used but only to add extra ports after a router.
Normally the router is not the issue, the Cable modem is normally what locks up."
this just seems wrong, even though i hate to disagree with an expert (although his field is more general electronics and entertainment).
i mean, since i dont want it to be any different than hooking up straight to the modem, isnt a switch what i want and not a router?
