Do you think you could do us a bit of a test between default drivers and the Cat 5.10a's? It'd be interesting to see if the 30-35% performance increase when using AA is accurate or not.nunyabiz said:As stated on the front page, ATI released the hotfix for opengl and also corrects an issue with serious sam2. This does support x1800 and corrects the temperature as reported in CCC. I am at 53c as we speak.
'parently so. It's not actually a "tool" but an optimisation for the X1K memory controller(s), so it will only work for those types of cards.mecdrox said:How does one enable this option?
Just download and install and it's good to go?
banGerprawN said:Do you think you could do us a bit of a test between default drivers and the Cat 5.10a's? It'd be interesting to see if the 30-35% performance increase when using AA is accurate or not.
Lazy_Moron said:So this hotfix only works on the X1x00 series? Not the X800, X600 and X300 series?
