I recently replaced my retail heatsink fan with a Zalman CNPS7000A-C on my P4. At first i used the zalman heatsink fan and I'm pretty sure I put too much. My cpu temps not overclocked were at around 45C idle and 57 with 100% processor utilization. So I purchased some arctic silver thermal paste hoping for some decrease in temps. I cleaned the processor well then applied the paste according to the instructions, by applying only a rice grain in the center and sliding my HS on top of the thermal grease:
But my temps are just about 2 degrees cooler! I also read on these forums that after 200 hours of use you'll notice a difference in temperature after you break it in so to speak. But I was certain I'd notice a bigger difference after applying the thermal grease a second time.....my idle temp right now is 43C.......I see people with their cpus overclocked at that temp and mines just at stock clock speed....Yes, i know you cant do much without a cool case but i have four fans at work, two intake and two exhaust.....I'm thinking of replacing the fans soon but I hope to see some improvement.....Of course my cpu is in no danger but I would expect my temps to be much lower....the fan on my heatsink is running at 2600 RPM is that what it should be running at? I know it needs to run slower to generate less noise but this is on normal mode (i took off the fanmate).......
