Hooking Up and Testing 710N
coastertux
I just got my Samsung 710N LCD and was wondering how I can test it and if I should use the analog out on my graphics card or the DVI out with the supplied DVI to VGA converter.
Just use the analog. There is no point in using the DVI out with the "DVI converter" since it doesn't really convert anything. You're still using the analog signal.
