redivulpis
- Sep 10, 2011
Hey guys, In the next few weeks I'm going to be getting my hands on THIS PSU for my SFF build. I'm looking to minimize the number and length of cables on this bugger, but I'm not in a great hurry to burn my house down in the process so rather than snip the extra cables (8-pin Intel Power cable is relatively useless in an AMD system) I'm going to instead make the PSU modular. I figure the best way to isolate unused cables is to actually use them, but not use them. I'm sure that makes sense to someone. Anyway, I do plan on single sleeving and shortening the ATX24 and 4-pin power cables, as well as the SATA power cables, most likely by snip-and-resolder, unless I can find an inexpensive way to recrimp them.
So, in order to do the modular conversion, I've determined to use phono-plugs similar to the ones found on Hiper modular PSUs (actually a few are from my old 580w Hiper). For the 8-pin Intel Power cable I plan on using an 8-pin version of this plug.
Is there any reason this should not work? I'm really just kinda throwing the idea out there, as I plan to do it whether it's a good idea or not, but before I go chopping up an $80, I'll probably practice on one of my spares I have laying around.
I'll be sure to post pics of the prototype and the finished product if it gets that far!
