GothicWombat
- Apr 27, 2005
Ok, here's the deal, I have this big old server case I want to mod but as i'm having trouble deciding what to do with it so i've decided to work on the one thing i know i must have when i'm done modding this case, in a wc setup. The thing is i think all the a lot of the parts for made for water cooling computers are overpriced so i was thinking of going oldschool and making my own.
so here is the plan get an aquarium/pond pump from a local petstore inclose the pump in a home made reservoir disguised as a ps, then use tubing from a local hardware store to connect it to store bought cpu and gpu blocks.
my biggest concern is the pump because although i've compared pumps from the petstore and ones on wcing sites and found extreemly superior as far as flow rate and about equal for max height i was wondering if anybody else had thought of this or ran into problems using aquarium/pond pumps in a water cooling setup?
also what inexpensive blocks do you reccomend for an amd 64 and a geforce 6800?
