Holy overclock batman....or linux info is wrong???
/dev/null
So I went into my bios and I decided to be conservative.
I have a P35 based gigabyte board.
266 * 9 is what is autodetected in bios.
So I set it to 400 * 6. No real overclocking, just raising memory bandwidth, no ? I dropped my memory multi (or something similar) to "2" so it showed 800mhz and matched my memory (I bought $34 ddr2-800 newegg sticks a week ago).
So I boot up, everything seems fine. Idle is a bit warmer than I expected (3-5C h igher ? ok, whatever....). I expect to be at 2.4ghz.
lo and behold....
rob2@rob:~$ cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
stepping : 11
cpu MHz : 3599.995
cache size : 4096 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm syscall nx lm constant_tsc pni monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr lahf_lm
bogomips : 7204.78
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 15
stepping : 11
cpu MHz : 3599.995
physical id : 0
siblings : 4
core id : 1
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
bogomips : 7200.14
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 15
stepping : 11
cpu MHz : 3599.995
physical id : 0
siblings : 4
core id : 3
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
bogomips : 7200.03
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 15
stepping : 11
cpu MHz : 3599.995
physical id : 0
siblings : 4
core id : 2
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
bogomips : 7200.03
clflush size : 64
power management:
Voltage is unchangd...bios said 1.2875.
Cooler is the coolermaster TX2.
Could this possibly be correct??? What is a good stability test in linux?
Ignore what /proc/cpuinfo says, when I had my E8400 I did the same thing (lowered it to 7.5 multiplier from 9 and put the fsb at 400), and it always showed 3600- even though it wasn't actually running at that. It's using your default multiplier of 9 for whatever reason instead of using what it's actually set at.
Ah thanks. I was going to say!!!
I am going to run some benchmarks and see what I can do at 2.4+
You can only change the multiplyer of the Xtreme series of chips. You know, the ones that cost a grand!!! All of the rest are multiplier locked. No matter what you set in the Bios, it will not change. It is the same with AMD. Only their Black edition chips are unlocked. All the rest are locked.
If you have speed step on, it will slow down to 6 mult when idle, but quickly jump back to 9 when busy.
Don
Don
the multiplier is not locked. you can set it anywhere from 6-9. True the ee parts are not capped like the mainstream, but my chip runs at 400x8=3.2, not 3.6
I can attest downclocking the multi seems to work well.
Povray 3.7 benchmark on 64-bit linux kernel 2.6.22-14:
2400: 386.92 seconds
2800: 331.939 seconds
3200: 290.1220 seconds
the box is running at 3200 @ 1.3125v
Not sure if I should go for 3600 or not. I also need a good long term stability test for linux before I go further.
I don't know of any. My first inclination would be vmware + fah or prime95. Maybe that would run in wine? who knows.
Cool, I stand corrected.
Don
I had the same issue where 400*8 was reading 3.6GHz in some programs like CPU-Z. Everest 4.20 however was reading it correctly.
