Hobby PSU
Where do I get one and is there one with a 4 pin molex connector to hook a pump so its easier to bleed? I'd rather have one of these to use to bleed than a $150+ PSU.
Thanks,
Mark
I have a USB-SATA/PATA kit that includes a seperate power supply with both Molex and SATA power headers. I'm not sure what kind of power they are rated for. If one of these is sufficient then you can find these kits on newegg if you search for "SATA adapter". I will check when I get home and see what the power supply is rated for. If that is no good then a laptop power supply of some kind might suffice with some cable modding.
Every house has dozens of various AC-DC power converters. It's just a question of voltage and output capacity if you are confident with your wiring skillz.
