hmmmm prime95 issue
timske
ok well here goes
I have been OC', my 2500 mobile on a msi k7n2 delta2 platinum for a few days now as i just got it.
so far best stable oc ive gotten is a 200x12 FSB doesnt like to go over 200 not sure if its the board or just how im running my memory which is OCZ3200 performance stuff gunna push the voltage on it and see if that helps or not anyhow.
I played doom3 all day yesterday (8hrs) and never had a single hichup with these settings.
tried to run prime 95 and it wont even get past the first test..... I find it hard to believe that I can blast my comp with doom3 for 8hrs and have no issues but not even be able to fast the first test in prime95 this is my first time using the software so im not so sure what i should be looking for.
sys specs
thermaltake 420ps with a/pfc
Moble 2500 @ 12x200
MSI-K7N2 Delta2 Platinum
768 OCZ 3200 el
WD-JB80
Saphire 9800pro
prime95 is a very proven program. it is very unlikely that there is a problem with prime95 that is causing it to crash. try increasing your vcore and see if it runs longer.
