Highest quality case under $50
SpongeBob
The Contraceptive Under the Sea
Hey guys, so I recently built a rig with a Lian Li case and it's made everything else I worked on feel like garbage. So after working on the sexiness that is Lian Li I now need a small case without a ton of mesh and holes and such for a NAS server. I do however want everything to fit, and there to be little if not any plastic. I would like to get quality on the cheap big points to someone who finds me something under $40 even.
Any good recommendations and who makes cases close to Lian Li quality? If you say Cooler Master I'm just going to laugh since I've owned 2 previously and their sides never sat flush and they are full of plastic. I will say the N200 is nice though but a bit too much is open with the front mesh
It's to run a Micro-atx board and standard size psu.
Thanks
Refurbished and looks massive. I am sure someone would definitely make good use of that I am definitely looking for something smaller.
What is a rebate "card" exactly from newegg?
Newegg's rebates generally come as a pre-paid VISA card that can be used pretty much anywhere. If it's under $10 they will send you a check. Just follow the directions and they are reliable, but expect about a 3 month turn around time.
