EnforcerGT
Bad Trader
- Feb 9, 2002
Ive been tryin to figure out a way to capture from my Sony TRV22 to my PC at a higher quality then it currently is. I connect it via USB rather than firewire which is basically the same to some extent, and its been working well. It is currently at 720x480 at best and it still looks a tad distorted. The preview is at 360x240 and looks ok nothing compared to pluging in my miniDV to the TV directly.
I know that the monitor is progressive scan while the TV is interlaced video at a much lower resolution, but I know there are ways to capture almost DVD quality to PC.
I just bought a P4 3.0ghz HT Chip so Im low on the funds.
Besides buying expensive equipment, anything else I can do? I have a couple bux laying around for this project. Any advice/help/commments all appreciated. Thx in advance.
