I sometimes go into standby mode on my computer so I can keep my workup without having to save a thousand things in bookmarks, and in different files..yeah yeah w/e..
Anyways the computer comes out of standby, my voltages skyrocket to somthing like 12.54 for the 12v, and all the others are high also. I normally have 11.94 constant with cpu/GPU full load. Now I was wondering I know how onboard sensors can be wrong sometimes and all, but do I really have anything to worry about, or should I just ignore these problems and forget about it?
Updated BIOS twice, no goood
Updated/Downgraded every possible driver
Had problem on my old 250w PSU, and same with current 350w.
I know high voltage is a killer of hardware and I dont want that so should I just not use standby and use hibernate, or not worry about it? What I'm concerned about is that its really giving out 12.54v and other high v on the other lines and that the hardware could be ruined.
No meter of any type that I can test this with.
Thanks, Dave.
Thanks, Dave.
