Help!?
hacktor2
i'm doing the Folding@Home and i got the tinker core and i just started running the graphic client... and the Next Frame End: says Tue 15 Feb 05 and the WU End says Thr 24 Feb 05....i thought that a WU could only last 3 days? what am i doing wrong?
my specs:
a7n8x deluxe
amd xp 2500 + @ 2.2Ghz
radeon 9800 pro
1024mb of GEIL pc-3200
120gig seagate 7200rpm 8mb cache
80gig seagate 7200rpm 8mb cache
EDIT: for some reason it just changed to friday the 18th thanks anyways
It should start to stabilize the longer it runs. Sometimes, esp the graphical client, will estimate these insanely large times. If you want a better gauge where your WU is sitting, EMIII is the best way to go.
The Time Per Frame will also reduce (sometimes 2x or more) when you arent using
your computer (ie when you are sleeping) as it is then using 100% of your CPU cycles
vs the 50% or less when you are running multiple app's or games etc
For faster folding times you can use the standard console version and then if you want to
see the graphics you can also use EMIII (has a feature you can turn on/off) to view it
