Help!!!
DRJ1014
HELP!!! I have been locked out of one of my folders. My brother locked me out of one of my folders and i dont know how to get back in. when i try to get in a message comes up and says Access Denied. How do i get back in?
I'll just assume that you are using Win2K. Here's how you do it:
1. Get on a user that has Administrative powers
2. Right click the folder you want and select ->
Properties -> Security (tab) -> (check box) Allow inheritable permissions from parent to propagate to this object
That should solve your problem.
ok heres the thing. I have my own computer and he has his own. he did this over the network. i am the admin and i still cant get in.
So what you're saying is that you have a folder of yours on his comp? If that's the case then you need to get on his comp with administrative powers and do as i stated or access it from the admin on his comp.
how do i insert an image everytime i do i get a red box with an X
no the folder is on my computer. he locked me out of my own folder on my computer over the network
Win2k: here are some other options->
1. Get on your administrator -> Users -> change his access to "Power Users" to limit his ability to change anything.
2. Again go to the folder your want and see if you can do the process. Please tell me if this works. This is how i set my network up with my bro sharing/using diff comps.
One more thing:
under the "Security" tab of the "Properties" of the folder you want to access see what "Names" are in the box with all the lists of who can access the folder. Try and see if you can "add" your self onto that list.
The administrator should be able to access all the files on the computer. If the admin couldn't access all the files then he couldn't do his job very well.
where would i find that
Originally posted by DRJ1014
how do i insert a pic i alwaz get that X
Where are you uploading the image to? Post a link and we'll see if we can access it directly.
pics: upload to site like www.theforumisdown.com then link the img using
[IMG ][ /IMG] caps no spaces between the [IMG
access users:
Start Menu -> Settings -> Control Panel -> Users and Passwords
access users:
he doesnt have a user account on this computer. as for the pic i make up a link then add the pic?
Pic you must upload to a file server then use the [img code to link it to that image u want posted.
If he doesn't have a user account then I'm not sure what he did. You might have to disconnect his connection to your network and try and figure out how to fix the system. My only suggestion is the "Right-click properties" on the folder you don't have access to and do as i listed before other then that i'm stumped on what to do. Sorry this is all i can do to help you. Maybe someone else is familiar and can help you out.
you can try this site ww.theforumisdown.com there is a UPLOAD button on the left side. Upload what pix you want and it will give u a link to your img then you can link the img to your posts
So he doesn't have an account on your computer, but he somehow changed the permissions of one of your folders and now the administrator can't even access it? How did he change the permissions of the folder?
im not sure how he did it. hes one of thse compueter freaks that knows just about everything.
i cant get it
your URL img link isn't correct
u must upload to a server and the server will have afile ready for you with a link like in www.geocities.com u can upload a pix into their file manager then u right click the link to the pix and copy it then do the [img ] link [ / img ]
where is the file manager on there
It's under the advanced toolbox on the right after you log in. There's also an easy upload right under that which would probably be easier.
