NightOps
- Aug 13, 2004
As stated above...I have a Linksys WRT54GS V1.0 running DD-WRT v.24 SP1 VPN.
I have a Windows 2003 R2 Server running DHCP/DNS for the LAN
Router is the VPN Server, with PPTP/IPSec/L2TP pass-through enabled.
I also have Port Forwarding setup for 1723, 500, 50-51 to the router IP (192.168.1.1)
Under PPTP Server I have the following:
Server IP: 192.168.1.1
Client IP: 192.168.1.151-160 (outside of the server's IP Pool range)
CHAPS-secret user * password *
Loopback: disabled
I have even set the router as the DMZ...still no luck
I am using the Windows XP Network Connection client.
When I go to connect, it hops right to Verifying username/password, but after about 15 seconds, it throws an Error 619, port was closed.
I've heard odd stories about a lack of true VPN support on the WRT54G/GS models that cause GRE packets to not get passed properly. I'm half tempted to get the DIR-655, but I want to check all possibilities before I go out and buy a $100 piece of hardware that may have the same issue(s).
I've verified that my IP address that I'm connecting from @ work does not fall within the range of IPs potentially assigned by the VPN.
Also, if I'm sitting @ home, I can connect on VPN locally without any problems on my Vista x86 machine.
Thanks!
Loopback: disabled
Thanks!
