Ok, I have not used any wireless networking stuff and trying to help my sister in law get this working better and get a good coverage out of this router: Belkin 802.11g Wireless DSL/Cable Gateway Router.
Here's the problem, her internet connection comes into her house on the second story and the router is located on the second story level. The router has two antennas on it and I left one straight up to cover the upstairs and tilted the other one at an angle so it would cover downstairs. The room where the pc is downstairs is one room over for where the router is, but I'm only able to get about 55% signal. She's having some problems getting the downstairs pc to surf because of the weak signal.
Shouldn't these routers get better coverage than this? Because real distance wise we're the downstairs pc is probably less than 15 feet away and is only going through the floor upstairs and one sheetrock wall downstairs.
I'm looking for suggestions on how to make the coverage better for upstairs and downstairs. I've noticed that Linksys make an antenna booster kit...which consist of bigger higher gain antennas that replaces the factory antennas.
SUGGESTIONS/HELP Please!
