help with rad choice for TEC setup
Willsonman
So, I have two 120 MM locations that I can put two different rads but one is on the side panel. I am really debating whetheror not to just mod my case further for this TEC setup to run a 240MM rad or 2 120mm rads. If I mod the case it would go on the side panel anyways. I'm trying to keep everything contained inside my case. I hate the look of everything outside the case. I am using a 320 watt pelt on the CPU and may add a 110 watt pelt to the GPU. I was planning on using BIP rads. Any suggestions?
120.3 mounted to the top. That is a lot of heat dumb to get rid of. I would do a 120.1 on one of the other fans between the cpu and gpu tech just to pull more heat.
Tech's are a dying breed though IMO. Might want to check out making a chiller as techs are getting to the breaking point of heat load and may not be worth putting a load of money into if you plan to go with a more powerful cpu or gpu later on.
GL on what ever you decide. Take pic's and post it up for all to learn from.
My 2 cents,
Scott
