Help with PCI RAID + Ultra ATA 100 problem
k-space
I'm trying to setup an older computer as a simple backup file storage system. I'm using an AMD 1GHz chip on an ASUS A7V MB. My RAID card is a Highpoint RocketRAID 133 which I had running fine for 2 years on an older system that has reached the end of it's lifespan. The problem I seem to be having is that the system uses a Ultra ATA 100 HD which it essentially treats as a SCSI device. The system will boot just fine (ATA 100 is the boot device) without the PCI RAID or with no HDs attached to it but when I attach the HD array it just locks up, thought it does recognize both the RAID array and the ATA HD. I've spent hours tweaking the bios with no luck. The RAID card bios show both HDs are attached and working correctly. It seems the MB thinks it has two seperate SCSI devices and just doesn't know what to do with both. That MB is one of the first to use the Ultra ATA 100 so it isn't the cleanest interface but I'm hoping someone might have a suggestion about how to get around the problem.
Thanks for any input you might have.
Dane R. Vinson
how many drives are you trying to use. if its just two cant you disable the ata100 and just use the raid controller?
you might wanna post everything you got hooked up, and how many drives, what type etc.
im no expert at raid. i have it on my two systems but had a hard time getting both of them setup correctly.
The ATA100 has the OS installed on it. Its been running XP Pro for about 2 years. I was really hoping to avoid having to reinstall the entire OS. The RAID array is RAID0 with 2x60 Gig 5400 RPM IDE drives. Nothing special just a basic backup system. The funny thing is I did the initial setup of the RAID array on a much older machine (AMD 400 MHz, Win2K Pro) two years ago and it went without a hitch. I had it up and running in a very short amount of time and its never given me even a hint of trouble. I'm almost certain the problem is that the MB doesn't have the vaguest idea what to do when it detects 2 devices it thinks are SCSI but I'd really love to find a way to end route it.
Thanks again,
Dane R. Vinson
