tylerdurden83
- Nov 22, 2007
Hello everyone. I'm going to try my very first overclock, and i hope that you can give me some help with it. My configuration is the following, and surely doesn't make overclocking particularly easy.
CPU: 2xopteron275
MOBO: Tyan Thunder K8WE s2895
Ram: 4xKingston 1GB DDR400 ECC Registered
GPU:8800 ultra
So, after having read several articles i understood that i can't overclock from the motherboard, or at least not just from it. Cutting it short, here is what i have done:
ECC off in bios
Powernow off in bios
Bus in bios @ 800 (is this the same as putting a 4x multiplier to the bus? i guess so)
Ram @ 333 (this loosens the ram frequency, but i haven't been able to find the traditional divider to set the ram and cpu to work not at 1:1 anymore)
Timings unchanged (on auto)
Then in windows, i put 1.4v with crystalcpuid, cpu multiplier left at 11.
Then slowly raised the bus with clockgen one click at a time.
Cinebench 2007 using 4 cores @ default 2.2 took me 2:10 minutes
Cinebench 2007 using 4 cores @ 2.3 took me 2:05 minutes
Cinebench 2007 using 4 cores @ default 2.4 stucks my machine near completion
Temperatures of the warmest cpu never got over 55 degrees even when at 2.4 (i'm using the boxed coolers).
CPU: 2xopteron275
GPU:8800 ultra
ECC off in bios
