intercollector
- Aug 5, 2003
Hi,
I'm having some serious temp problems. Here are the specs:
A64 3000+ newcastle C0
DFI Lanparty 250Gb
1GB Pc3200 ram
Zalman 7000A-Cu
For cooling setup, I have an antec case with an 80mm side fan with an air duct blowing cold air directly on the Zalman. For case fans, I have 1 front 80mm fan and 1 120mm exhaust fan out the back.
At stock speeds I get 42c CPU temp (35c case) at idle. Already they seem a bit high. Under load it jumps to about 49c and 37c.
I can overclock to 2550mhz (255HTT, 3/4 ratio....ya ya, I know my ram sucks)
I get pretty sweet scores in SuperPi: 36s for 1M
But my temps jump up to 42c case and 60c+ CPU under load.
I was hoping the Zalman could do I ton better than this. I have the Zalman fan running at full tilt.
Currently I have it running at 225HTT, with ratio at 1:1. Seems to be a pretty good performance with decent enough temps to have it run at this all the time. But I was hoping that getting the Zalman would let me run 250HTT with temps around 45-50c under load, as is the case with other people with similar setups.
Any help would be appreciated.
DFI Lanparty 250Gb
1GB Pc3200 ram
Zalman 7000A-Cu
