Help with Headers
rudedog89
I got a new AMS gmono CF2029 and the front i/o has different kind of header labels than what is listed on my mother board. Please someone help me figure out what goes where on the audio.
Here is my motherboard header... I have a A7N8X deluxe:
M/B Audio Header
Mic2 . . AGND
MicPwr . . +5VA
Line out_R . . BLine_Out_R
NC .
Line out_L . . BLine_Out_L
Front I/O cable
Microphone
Micbias
Ground Line
Speaker R
Speaker L
Return R
Return L
By looking at this I have some idea what goes were, but, still a little confusing to me.
Thanks
M/B Audio Header
Mic2 . . AGND
MicPwr . . +5VA
NC .
Front I/O cable
Microphone
Micbias
Ground Line
Speaker R
Speaker L
Return R
Return L
Thanks
Those are your Front Panel Audio connectors. You can re-route your audio from the back to the front of the case.
Novensu
Mic2 is Microphone
AGND is Ground Line
MicBias I would guess is MicPwr--I can't think of anything else it would be.
SpeakerR should be Line out_R
ReturnR should be BLine_Out_R
Similarly for SpeakerL and ReturnL
^^ This could be reversed. Try it one way, and see if you get sound into your headphones. If you don't hear anything, switch so SpeakerR->BLine_Out_R. However, I'm looking at my MB manual (which is just as cryptic, but I've made notes from actually hooking up the front ports), and I have ports that are laid out exactly the same way. So I'm pretty sure that Line_Out_R carries the signal TO the panel, and BLine_Out_R comes FROM the panel(return).
