Help with graphic card
bullseye
Hello all this is my first post and i need your enlightment,
I have this motherboard Gigabyte Technology Co., Ltd. 945P-S3 (Socket 775) rev 1.0
and i need to upgrade my current gpu which is 1024MB NVIDIA GeForce 9400 GT (Point of View). All i need is a cheap GPU that will allow me to play games at least more than 10fps.Any suggestions? i live in greece btw and there are 2 links that you can suggest me from.1) http://www.e-shop.gr/search_main.phtml?table=PER&&category=%CA%C1%D1%D4%C1+%C3%D1%C1%D6%C9%CA%D9%CD&filter-363=1
2)http://www.skroutz.gr/c/55/kartes-grafikwn-vga.html
Thank you a lot if someone help me :D
Max i can spend is 50euro.
All my pc Specs
Operating System
Windows 7 Ultimate 32-bit SP1
CPU
Intel Core 2 Duo E6400 @ 2.13GHz 54 °C
Conroe 65nm Technology
RAM
3,00GB Dual-Channel DDR2 @ 351MHz (4-4-4-12)
Motherboard
Gigabyte Technology Co., Ltd. 945P-S3 (Socket 775) 50 °C
Graphics
E2241 (1920x1080@60Hz)
LCD170V (1280x1024@60Hz)
1024MB NVIDIA GeForce 9400 GT (Point of View) 52 °C
Hard Drives
233GB Hitachi HDT725025VLA380 ATA Device (SATA) 36 °C
Optical Drives
SONY DVD RW DW-Q120A ATA Device
DTSOFT Virtual CdRom Device
Audio
Realtek High Definition Audio
Power Supply 420W
I see that you have two lcds listed. Is it required for the new video card to have dual-DVI connectors?
Do you need DVI & svga connectors?
is there a maximum price (budget) for you?
Does your power supply have a 6-pin PCI-E power connector?
My first thought for entry level gaming is a Radeon 7770, but it only has DVI, HDMI and displayport. It also requires a 6-pin power connector, which your power supply is indeterminate quality, so I would even hesitate to recommend a video card that requires supplementary power.
yeah i need 2 lcds inputs, i am not sure about the 6 pin connector,max budget is 50euro my power supply is 420W if u gimme a link of the pin i will answer u soon.
50 euros is not enough for entry level gaming.
The options are basically limited to either a Geforce 610, 620 or Radeon 6450. Those cards are designed to play videos and connect to TVs, not play games.
If you want to play games, the minimum you should get is a Radeon 7750 or 7770
or a Geforce GTX650. These all cost at least 90 euros.
atm i am out of money and until january or march i need a lil bit of improvement in a low cost.do u think these models u mentioned will improve a bit my performance?
rift,league of legends,counter strike source,teamfortress,rift is the heavier!
You really should get at least a Radeon 7750.
http://www.skroutz.gr/s/2641838/Sapphire-Radeon-HD7750-1GB-DDR3.html
But if you need to keep the price down, get a Geforce 630 or a Radeon 6570.
http://www.skroutz.gr/s/422687/Sapphire-Radeon-HD6570-1GB-11191-26-20G.html
http://www.skroutz.gr/s/2162707/MSI-GeForce-GT630-1GB.html
or
http://www.skroutz.gr/s/2103782/MSI-GeForce-GT630-2GB.html
I don't think that 1GB or 2GB will be any noticeable performance difference.
yes, these cards are faster than your current Geforce 9400.
by the way something else i noticed about my mobo pci input.Wont the memory speed get halved from the GPU? i think its not pci-e 2.0 its just version 1.0 will i have any problem with compatabilty?
the PCI-e slot on your motherboard is compatible with pci-e 2.0 compliant video cards.
for the video cards you're looking at, it's not even close to being limited by the slot bandwidth.
So yes, it will work fine and performance is not limited by the pci-e slot on your motherboard.
