Help with a new build!
Manimal29
First off, the hardware:
GA-EP35C-DS3R 775 ATX Motherboard
Intel Core 2 Duo E8400 3.0GHz Processor
OCZ Platinum XTC Series 2GB PC-6400 DDR2 Revision 2 ram
Visiontek Radeon HD 3850 256MB GDDR3 PCI-E Video Card
Corsair HX Series 620 Watt ATX 12V Modular Power Supply
The bottom line is I have no video. I am unable to tell you what the bios rev is because I have no video. I bought the motherboard, ram, cpu and video card all brand new. I assembled the machine using proper ESD mats and straps with no issues. I powered the machine up with no monitor attached to simply verify that everything powered up. I received no post beeps of any sort. I then took the machine and attached it to a monitor and got no display. I re-checked all of my connections and tried again with the same result. At this point, I tried a different PCI-E video card. Same result. So far I have tried a EVGA 6600GT, a EVGA 6800GS, and the Visiontek HD3850 I just purchased. No video. I have tried two different monitors. Same result. I get no display at all. The power supply is a Corsair HX620 and the six pin power is connected to the video card. The hard drive is a Western Digital 74 GB Raptor that was in the machine prior to the parts upgrade and has Windows XP Pro/SP2 on it. My intent was to rebuild it with a fresh OS install once I can get video. As a last resort, I removed the ram to see if I could get any beeps from the motherboard. Sure enough on power up without ram, I got the expected beeps from the motherboard. I am at a loss and REALLY need assistance. Any and all help or suggestions are GREATLY appreciated!
take everything apart and reseat the ram and cpu and also assemble the system outside of the case and test it just in case you would be grounding your motherboard on your case some how , and also try resetting your boards bios
I have reseated everything except for the CPU. Is there any other way, short of removing everything, to determine if the motherboard is grounding out on the case?
I just did a new build last night and had this exact same issue. I tried all different video slots (dvi, vga, onboard, etc.). After clearing the CMOS, the system started displaying video for some reason. That is an easy fix...but I was preparing to remove everything and run it outside of the case at that point, so I can understand your frustration.
And to answer your question, I can't think of a way to test for shorting without full removal.
Jason
If reseating all componets and reseting the cmos fails, i would take the board back and try a new mobo, over the years i have had a hand full of mainboards that just plain did not work for whatever reason brand new out of the box (often cheap brands like ECS are the worst for being DOA)
UUUUUUUUUUUUUUGGGGGGGGGGGGGHHHHHHHHHHH! I feel ridiculous saying this now after all of the help, but when I originally composed this post, I put down the wrong Model # for my board! The CORRECT Model is the GA-P35-DS3R, NOT the GA-EP35-DS3R. Does anyone have anymore ideas?!
