Help with 8rda+! Computer keeps restarting after Iceberq installation
MajinWu
Whenever Windows XP gets done loading, my computer just restarts for no reason. Only when I'm in Safe Mode can I have my computer stable... but sometimes it still restarts while in Safe... My computer was working just fine until I installed the following:
a Vantec Iceberq on my northbride chipset. I used Arctic Silver 5 and used the pin inserts to mount it to the chipset.
one of the heatsinks that came with the Iceberq package on my southbridge using thermal tape.
another one of the heatsinks from Iceberq package on the heatspreader of my vid card.
reapplied some arctic silver 3 to my CPU (it used to use arctic silver 5... but I just wanted to use arctic silver 3 again)
My Rig is as follows (from my hardforum sig)...
AMD Barton 2800+ @3200+ (200x11) || Thermalright SP97 + Zalman ZM-F2 || Epox 8RDA+ Rev 2.1 || Powercolor Radeon 9700 || Turtle Beach Santa Cruz || 2x256MB Kingston HyperX PC3200 Dual Channel || WD 80GB + 160GB || Antec Sonata Case + 2x120mm case fan || Antec TruePower 380s ||
I tried setting my system back down to factory defaults, and the problem still persists!
I'm suspicious on the Northbridge... maybe it doesnt have good contact with the Iceberq... Please help!
have u tried removing all of those components that you've newly installed?
try taking out those after market heatsinks and put the stock ones back on
I'll give that a try... it wont be the same since I removed the stock thermal "gum" that sticks the stock heatsink on the NB. Now there's the thermal tape that came with the Iceberq package. I donno if that would improve or worsen the situation. And I don't have any thermal glue lying around either.
Still no good
I reinstalled the Iceberq with thermal tape this time. I also took out my extra ethernet card and Santa Cruz sound card. The same problem persists... I touched the Iceburg and it didnt feel warm or cold. It just felt normal... My stock passive heatsink would feel pretty hot; maybe the Iceburq isn't hot because of the fan acting in...
I guess I can try putting the stock passive heatsinks back onto my Northbridge and Southbridge... but it wont be the same since I don't have any of that thermal "gum" that stuck the two onto the chipsets... I only have the thermal tape that's installed right now. Tearing off and putting back on heatsinks would lower its adhesiveness, too. Do thermal tapes perform worse than thermal "gum" (or whatever its called)
What else can I do??
Well, I've reinstalled the stock passive epox heatsink onto the NB now... and my computer still keeps restarting after winxp gets done booting (about 20 seconds after I enter my password and the desktop shows up). I used thermal paste that came with the Iceburg package and the stock spring-loaded pins to install the heatsink. There's definitely good contact because when I touch the heatsink it's pretty hot. I really can't think of anything to do...
Reinstall vid card drivers? Reinstall winxp? (plz, God, no)
FINALLY, making some progress... My computer is just about back to normal. I turned off all 3rd party apps from my start up list in msconfig and reinstalled my vid card drivers. That allowed me to get to WinXP normally without restarting. Then I ran a virus scan and realized that I have Worm Nachi... so it deleted that. Then when i tried some stuff around and realized that whenever I change my Logitech MouseWare properties, the computer restarts... so I uninstalled that and reinstalled it again, and now I think my computer is just about cured! Turns out it wasn't a hardware problem at all, but Windows...
Originally posted by infinite12
I would backup all your important files and do a reinstall anyways, just to be safe.
yes, a clean format wouldnt hurt :D
