My old desktop has an ancient PCI Sound Blaster Recon and my nephew has on board audio. How can 10% global/master volume on my desktop be louder than his 20-30% global volume under the same test conditions?
I use an old pair of HD 595's and I bought him a pair of HD 598's. The only difference is I have PCI 3.5mm running Windows 7, and he is using the front audio out from his case running Windows 10.
Are the 3.5mm ports providing variable amounts of current/voltage? Is it a driver issue? Or is audio volume variable across boards?
