I JUST finished installing my new system. New gigabyte motherboard, new seagate 320GB hard drive, new video card, new screen. Ok.
So I install windows and I see NTFS has a 130GB limit. I understand the limit is set by the windows version, but I install it anyway thinking that I'll patch it with SP2 later.
Now, I'm encountering a number of weird problems such as described in this quote :
My Nvidia Control Panel crashes on launch, and when I right click / save as - a picture from the internet, it doesn't save it and says the file doesn't exist. If I drag/drop it, it is corrupted.
What the ...
Other than that everything's great, its just that I dont like having errors when I launch windows for the first time!
When I shutdown my magic rotation software also doesnt close properly and crashes. Wow, that's weird!
Could it all be caused by my NTFS drive? Is the drive faulty or is it just not working well on the current partition that was set-up by windows boot disc?
Thanks!
SYMPTOMS
If your computer has an ATA Packet Interface (ATAPI) hard disk that is larger than 137 gigabytes (GB), you may experience any of the following symptoms:
Your computer may restart instead of resuming from hibernation.
You may experience hard disk corruption when your computer enters either standby or hibernation.
You may experience hard disk corruption when Windows XP writes a memory dump file as a result of an unrecoverable Windows error (or Stop error)
Note If you experience hard disk corruption, you may also experience other symptoms including problems starting, restarting, or shutting down Windows XP, problems running programs, or problems opening or saving documents.
What the ...
Thanks!
