Help w/ Sapphire mobo
HaX
Well my computer was working fine up until a few days ago. I took out the hard drive and placed it in another machine, then I put it back into the original machine and did a fresh install. I have to use a sata driver floppy during the install so it'll detect the hard drive.
I installed the sata drivers (i might've installed the wrong ones there the si3112 and si3132 drivers. I think of I might of installed si3132 drivers on mistake when they should of been the si3112. But anyhoo i installed the drivers and then installed windows xp pro. On the reboot after the install, it prompted with an error like something didn't install properly from the windows cd. I rebooted and then the sata drive won't be detect anymore.
I tried installing windows xp on my ide hard drive and it worked fine. I went into disk management and was able to see and access my sata drive. I deleted the partition (there was the windows folder on the drive). I reboot and use the si3112 driver disk and my hard won't be seen. What's the deal?
you can try the following: boot from winxp cd, do not install the driver again, delete and create the winxp partition in the listing page, continue with installation. the is a small chance your winxp cd is a bit dirty(had a problem with errors from a copy a while ago, had to use the original cd instead).
nvm, i got this working... i was using the wrong sata drivers :eek:
