1) What will you be doing with this PC?
Browsing the web, occasional video editing but nothing serious enough to warrant a graphics card.
300-400$. Yes tax and shipping included.
3) Where do you live?
Tennessee, USA
4) What exact parts do you need for that budget?
Motherboard, CPU, Memory, PSU, HDD, Case
Note: No VGA card is listed. It is not necessary for this build, but I do need a way of connecting the monitor obviously. If its more efficient and/or cheaper to get a video card then I am up for that instead of getting a mobo with an on board GPU.
5) If reusing any parts, what parts will you be reusing?
Not reusing parts.
6) Will you be overclocking?
No
Dell 2007FP
I plan on buying it as soon as possible in order to take advantage of any Black Friday deals.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support?
Nothing fancy like SLI or RAID. Just the latest technologies, like SATA, maybe some type of integrated GPU, etc
10) Do you already have a legit and reusable/transferable OS key/license?
Yes - Windows 7 64bit
Additional Information:
I plan on using the heatsink that comes with the CPU, fans that come with the case and I do not want to do anything fancy. I would prefer the case to be a mid-tower that is cheap but sturdy and to stick with products from well known manufacturers like Asus, Intel, AMD, and Corsair even if it means paying a little extra.
I have decided on the following, but I came here in hopes that you guys could enlighten me to some Black Firday deals.
CPU: Intel Core 2 Quad Q8300 - 140$
Motherboard: EVGA 113-YW-E115-TR - 110$
HDD: WD Caviar Black 640 GB - 50$
Memory: GSKILL 2x2GB PC2-6400 Dual Channel Kit - 94$
Case: CoolerMaster Centurion 5 - 50$
PSU: Corsair 400CX - 40$
So this is about 85$ over my 400$ price range. I was hoping you guys would be able to bring it down, or suggest a entirely different setup with equal or better performance for cheaper.
Thanks for the suggestions in advance!
Tennessee, USA
Not reusing parts.
No
Dell 2007FP
