Alright,
I have been having a b*tch of a problem with this board since December. I then tried to set up a RAID 0 array but ended up not doing so and just installed everything onto one of the two WD Raptors (36.7GB). I decided tonight to do a reformat for performance sakes and whatnot, and I thought that I would give the ol raid array another shot since I had figured out what went wrong the first time.
Fast forward to tonight. I make a boot disk and format the C drive. now I start from scratch. I got the Intel 865 chipset RAID drivers that I need to install after pushing F6 during windows xp installation. I create the Raid 0 volume in the intel raid bios and I set up the AMI bios on the board to accomadate a RAID 0 array. Its fairly easy, in the IDE Config menu. I get to the windows installation, hit F6, drivers load ok, everythign goes well, windows prompts me to select the volume onto which I will install the OS. it sees the 65 GB array fine and I opt to install XP onto that. After all the jazz, it give the dialog that it will reboot in 15 seconds and I am to remove my floppy. I do and it reboots. but now when it reboots, it goes right back into Windows setup, which I have already done. and it wants to do everything again. I am on my second or third install, I am not sure which. if anyone has any pointers and or tips they are greatly appreciated. Maybe it is a setting in the BIOS that I am overlooking or perhaps a goofy boot order. please help me shed some light ib this annoying problem. thanks
Andrew
Andrew
