help... stuck on extended desktop!
Apathy
help. installed new video card drivers. monitor set itself as extended desktop. ati 3870x2. cant see desktop to change settings. posting from cellphone. what to do?
tried plugging in two different 2nd monitors into card. does not detect signal. tried both dvi ports. advice please?
problem solved...., posting from pc now. was able to drag the ccc over to extended desktop after about 100 blind clicks and drags. very annoying. is there a simple fix for this so that i know for the future?
Hehe, this was a popular issue when dual monitors weren't as popular (late 90's/early 2k)...
  1. alt+tab to the app
  2. alt+space
  3. m
  4. arrow key (any direction)
  5. move mouse around
This should work in most cases. ;)
I still use that when running dual monitors. Sometimes a window will pop up too high and your not able to grab the bar at the top of that window to drag it down.
1. alt+space
2. m
3. arrow key (hit down arrow)
4. enter
This works good everytime hehe
  2. alt+space
  3. m
ahhh, thank you enginurd and hardwareguru. i just tried this and practiced a bit just incase it happens again.
this will probably end up saving me a decent amount of frustration in the future.
thanks guys.
