Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm sleeving my PSU right now and I removed the floppy molex. However, i cant figure how to get it back in. I put it back but its just loose and comes out, never clicks in. What do you have to do to it so that it stays in? Thanks a lot
On the floppy molex, there's only one little tab. You may need to bend it back out. These connectors only go back into the plastic part one way, so make sure you're doing it right.
I had the same problem. The tab that you pushed on to get the connector out has bent the other way and needs to be "popped" back out before you can get it to go back in and stay there.
